symmetry constraint results into massive screen lag
cekuhnen
Mentor Mentor
cekuhnen
deleting the symmetry constraints instantly speeds up the screen refresh rate when moving or zooming.
all settings are set to low - grid is off - profiles hidden.
this performance is very concerning with the new June update.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
And this lag issue is only on Mac OS right?  And the constrained color indicator preview feature is turned off?
Jesse
cekuhnen
Yes sketch preview is turned off as well.
Something else is happening here on Mac Side.
The Win side inside the sketch engine is fine.
The UI redraw speed is so slow it is utterly hard to work fast and accurate with this current build
resulting in mis clicks left and right.
File is attached
Claas Kuhnen
innovatenate
Autodesk Support
Autodesk Support
This is just for panning zooming and orbiting, correct? I
I'm doing a quick little test on may machines here.
Mac Mini (Late 2012)
8GB RAM
Intel HD Graphics 4000 (1 GB Dedicated VRAM)
Mac OS 10.10.2
vs.
HP Z600 Workstation
24 GB RAM
NVIDIA Quadro 5000 (2.5 GB Dedicated VRAM)
Windows 7 64 bit
Even while editing the spline, I'm not really noting a huge difference between the two.
Would you mind recording a quick screencast showing what steps you're following?
Nathan Chandler
Principal Specialist
cekuhnen
here is a screen cast with a simple sketch.
the issue affects everthing of the UI zoom in out drag draw etc.
the moment the symetry constraints are gone everything is fast again.
https://drive.google.com/file/d/0Byzv_NlyKp_2UnJzaEdtbGpvZU0/view?usp=sharing
Claas Kuhnen
