Switching to Design workspace from 3D pcb workspace to build the enclosure
Hello!
I am a computer engineering student.
Recently, I have installed Eagle and Fusion 360.
I have built the schematic and pcb using Eagle and then pushed the pcb into Fusion 360.
But whenever I open the pcb in Fusion 360 to build the enclosure, I can't find the design workspace. I am seeing 3D pcb workspace and other workspaces.
I want the default Design workspace that I usually see after opening Fusion 360.
How can I do that?
Why am I seeing the 3D pcb workspace?
When I tried this in my university lab, it was okay. But when I have installed Eagle and Fusion 360 in my laptop, I am facing this problem.
Thanks in advance!
TheCADWhisperer
Can you File>Export and then Attach example *.f3d file here?
Thanks for your reply!
Please find the attached file.
Khaled Ahmed
rbgorbet
Observer
Observer
@Anonymous  did you ever get an answer to this question?  I have the same one, @TheCADWhisperer .  I created a board in Eagle, pushed to Fusion360, and when I open it in F360 I only see the following options for workspaces.  I'm trying to follow the tutorial videos here to build an enclosure, but these videos start in the Design workspace, which I don't seem to be able to access.
Perhaps I can export a model of the PCB and import that into a new F360 workspace, but that seems a bit silly (if it even would work).
Thanks for any suggestions you can provide!
