Switch Section direction in Drawing
jasonhomrighaus
jasonhomrighaus
Im trying to set 2 views of a truck body so i can see both halves.  I setup a pair of sections on the same line but one in each direction.  However, the second section flipped itself so that it looks the same way.  Is there a way to force it to look the opposite direction?
Jason
jhackney1972
Select the section line and you will see three grips.  You can left click drag on the ones in the corner to reverse the direction of the section view.  A word of caution, it will snap to the same angle of the original before you started but if you let the left click go before the snap point, you will have a hard time getting it back to the original angle.
John Hackney, Retired
Nikola_Kolev
I have the same problem - how to switch the section direction in drawing ? Screenshot 2026-04-01 140938.jpg
