Switch holes from top to bottom
geryggTL98L
geryggTL98L
Hi! This may be extremely easy but I have no idea where to start...
I need to switch the holes and the "little mountains" from the top to the bottom.
It's a .stl so first step I insert in to Fusion as Mesh.
Second step should I convert it to solid?
Third step no idea how to select the desired faces, cut them and place them at the exact position.
Thanks a lot!
g-andresen
If you want a clean result, create this simple design from scratch.
Günther
jhackney1972
Here is your file with the pins placed on the other side.
John Hackney, Retired
geryggTL98L
Hi John!
Great, the pins are in the exact place where I need them, but I still need to make the holes from the bottom go into the top. Do you know how to do that?
Could you please guide me through the steps you are doing for me to learn aswell?
Thanks a lot!
jhackney1972
I have attached the second modified STL body with the switched holes and pins.  I am working on the video and will attach it in a few minutes.
jhackney1972
Here is the video I promised.  The model is a bit out of square so I had to stop and start the video to fix a few issues.  I hope you get the gist of process.  Please do not forget to select the Accept Solution if this answered you question, ask if you have further questions.
geryggTL98L
Great John, thanks a lot! I understood perfectly what you've taught me, I'll try to do it myself tomorrow.
Thanks again!!
