Sweeping along a Path without the profile being on the path
djrobert
Message 1 of 11
djrobert
I am attempting to create a model for some neon lights. I've got multiple paths I want to sweep a sketch over. But since the sketch isn't on the sweep path It will fail. I can redefine the sketch plane but since this isn't a Timeline action it will only work for one sweep. Is there any other solution besides duplicating the sketch a bunch?
For an example of the sketch and the paths:
Replies (10)
Message 2 of 11
g-andresen
1. create a "plane along path" for each path
2. copy 1. sketch and paste into several  sketches
Screencast
günther
Message 3 of 11
djrobert
Yeah this works, but creates many duplicate sketches. If I then change a Dimension in 1 it  won't update in the others. Would be nice if there was a way to select a point that should be used for the intersection or something.
Message 4 of 11
g-andresen
If you define variables in the parameter list for the 1st sketch, these are carried along when copying and you can make changes for all of them in the parameter list at the same time.
günther
Message 5 of 11
TrippyLighting
Can you share your model ?
Message 6 of 11
djrobert
 This is an oversimplified version of the original file. I want to extrude this sketch along the 2 splines
Message 7 of 11
TheCADWhisperer
In the file that you Attached the Profile is not perpendicular to the path?
Message 8 of 11
djrobert
Yes, that's the whole point. It can't be because it has to be along multiple curves.
Message 9 of 11
TheCADWhisperer
You have to do the work in Fusion 360.
You haven't started first step correctly.
Autodesk Inventor Professional has Sketch Blocks that you can use to automate this.  (See @TrippyLighting similar approach using Component below.) 🤔
Autodesk AutoCAD will Align your profile to the path, but there are limitations with that assuming all are on same axis.
Message 10 of 11
TrippyLighting
No, it isn't, and you can!
You can put the profile sketch into a component and then assemble the component to the end of all your splines.
Message 11 of 11
djrobert
Yes perfect. Doing it with a component solves it indeed. Thank You!
