sweep problem
sweep problem
Message 1 of 38
sweep problem
I recently put up a post call revolve problem, I had most of my problem answer but not total. i have created with an off set plane and use sweep to create my curve and key way on my cylinder, the problem i am having is i need to create the same cut away on the opposite side but the cut away keyway is stopping me to complete off set plane, so i can project the same curve on the other side, so i need help on how to do it. here is an attachment that i am trying to do.
Thank you for help
Regards Paul.
Replies (37)
Message 21 of 38
So i look at you sketch, you have said to draw 60m by 65mm, but looking at the sketch it looks like 32.5mm H by 65mm
Is that what you meant, Sorry i am only new to Cad, by a few months.
Thank you.
Happy to sketch either way.
Regards Paul
Message 22 of 38
TheCADWhisperer
Note the diameter Ø symbol.
I am going to walk though this similar to working on a Lathe.
Do you have any experience turning parts on a Lathe?
The rectangle will be revolved about the Z axis (blue) resulting in a cylinder with diameter of 65.
So to dimension - click the axis line and then the outer line, right click and select Diameter as the dimension type.
When we get to Sketch 2, 3, 4 & 5 you will see why I did the Sketch 1 in this way.
Message 23 of 38
Sorry for my slow response, i have been traveling over the last 10 days, with only a bit of internet. i am home tomorrow so i do this straight away, thank you for your help.
I have use a lath before. So i get what you are saying.
Regards Paul
Message 24 of 38
Sorry can you please make a video on how you do this from the start, slowly. not really understanding how you got the circle dimension. So are you able to do the whole sweep or evolve. I made an evolve with a grove but i couldn't get an angle on it, so i am happy to learn from you. I feel if i see how you do in in a video then that would make it easlyeir, but i need it slower, with no short cuts.
Only if you have time.
I a little stuck.
Regards Paul
Message 25 of 38
TheCADWhisperer
This video demonstrates creating the first sketch with a diametral dimension.
Turn on your sound.
Message 26 of 38
TheCADWhisperer
It is easier to edit geometry if you keep the sketches simple.
This video demonstrates the Keep It Simple Sketching.
Message 27 of 38
TheCADWhisperer
Once you get the hang of it - KISSing is easy.
Message 28 of 38
TheCADWhisperer
Rectangles (and Circles) are the foundation of sketching.
Message 29 of 38
Thank you,
The mistake i made was i drew a rectangle by using the single line, i will do this and get back to you.
Thank you, you are very kind to teach me
Message 30 of 38
Ok i have done what you told me to do, I have repeated all these steps and have 4 sketches, So i wait until you post more, I will say thank you so much for your time and you are fantastic at explaining step by step what to do.
Thank you Again
Regards Paul
Message 31 of 38
TheCADWhisperer
Message 32 of 38
TheCADWhisperer
 What do you want for the Pitch of the swept groove and how many degrees of rotation should the groove go around the part?
Message 33 of 38
Hello , I am falling the video, but on sketch 5 when i high light the lines, I am not getting the same thing happen with my lines as your, i will post a picture
Message 34 of 38
Hello can you please check my file if i am the right track.
Thank you
Message 35 of 38
Ok i have done that, i sorted the problem, Here my screen shot
Message 36 of 38
Thank you for teaching me, Ok i understand why you making separate sketches now. I use the revolve tool in the pass. But i always made 1 sketch, which mean any time i need change i had to go back to my first sketch and i was not using dimension tool either, or normal/construction lines.
so thank you for teaching me this.
So i am now up to date and i wait until you can post more, thank you so much.
Regards Paul
Message 37 of 38
TrippyLighting
My advice here won't be very  detailed but I believe there is enough detail in this thread as it directly applies to the sweep cut you are trying to make, the only difference being that in the linked thread the user mills down to the center of the cylinder, which makes it more convenient for him as he only needs one helix (3D sketch splines), while you need two.
Here is a link directly to the Screencast the user in the linked thread prepared. This should set you on the right path ad if you like the screencast, maybe give him another kudos in that thread. I tried to accomplish this using the Coil tool, but that tool is about one of the most dysfunctional tools in Fusion 360, so I'd stick with the 3D sketch spline approach this user is using:
Message 38 of 38
thank you, this is another way of doing it.
