Sweep on two different planes
andrecasselbergs
Message 1 of 30
andrecasselbergs
Good day folks. I’m a hobbiest using Fusion 360 to make kids toys/games for my grandkids.
 I’m trying to create a “ramp” into which a marble enters on a down slope, goes around a 90 degree turn then continues down an exit slope in the opposite direction. I’ve tried to set up two opposite planes using the “two lines” command and creating a sweep from each end to meet in the middle but without success. I’m sure there must be an easier way.
Sorry, can’t offer a model as I haven’t been able to get one to work well enough. I would be really pleased to get a solution. Sorry, just for clarity, some of my components including this one, are 3D-printed.
Replies (29)
Message 2 of 30
davebYYPCU
Like this one?
Step along the timeline, I extruded top view of the path, and split the body with the 20 degree ramp,
Made a hollow Pipe, on the ramp edge, and used the same cutter to make the top half disappear.
Might help....
Message 3 of 30
wersy
Message 4 of 30
Warmingup1953
Message 5 of 30
andrecasselbergs
Yes, through 180 degrees but it has to be a rounded turn and the turn also needs to continue the downward angle. The example you show would not guarantee that a marble would continue on its way.
The way that would work best would be to have a sweep that results in a smooth flow. The actual application of the sweep would be to “bore” a passage through a body where the marble goes in one end and comes out in the opposite direction 10mm lower down.
Tomorrow (my time) I could probably post a screen shot of where I’ve got to but it’s really not a clever or functional example.
 Thanks so far.
Message 6 of 30
davebYYPCU
For a drop of 10mm, and a constant ramp,
same techniques, just different shapes.
Might help....
Message 7 of 30
andrecasselbergs
Thanks, I’ll take some time tomorrow to digest, bedtime now 😁
Message 8 of 30
andrecasselbergs
Thanks will have a look.
Message 9 of 30
laughingcreek
the sheetmetal workspace is an easy way to get a constant slope down the entire run. see attached model-
Message 10 of 30
wersy
Ingenious!
One more reason to get involved with sheetmetal workspace more often.
Message 11 of 30
wersy
It is unbelievable what can be bent!
Thank you @laughingcreek !
Message 12 of 30
laughingcreek
you can also bank the curves if things get going to fast.
Message 13 of 30
andrecasselbergs
Thanks for all the responses. The reply from laughingcreek is really cool and I’ll investigate that a bit further - never considered using sheet metal in this application.
It is apparent though that I haven’t made the goal as clear as I could have. My intent is not to create an external ramp but rather a “tunnel” that will cut through a solid body. I would be excited to see what the boffins can produce. I’ll post a picture of what I’m trying to achieve during today.
I’ll spend some time on the replies so far and learn lots. Thanks guys.
Message 14 of 30
andrecasselbergs
So this is an example of where I need to go. I made this by hand out of hardwood. My marble races are a combination of materials (wood, stainless steel, 3D prints) and I want to make the little carousel in 3D.
29A5E096-EF00-4114-8B5A-E5210948FB79.jpegSo it’s the little tunnel that goes in, loops around and comes out 180 degrees an 10mm lower that I need to “drill” into the body..
Hope this is clearer.
Message 15 of 30
andrecasselbergs
@laughingcreek : I just had a look at your model. For me, that’s ingenious, taught me a lot about ease of use. Thanks a lot for that.
Message 16 of 30
andrecasselbergs
Can someone help me with uploading a model from Fusion 360 to this forum?
Message 17 of 30
Warmingup1953
I don't believe it!...But I'm going to download and illuminate myself! Fantastic work.
Message 18 of 30
davebYYPCU
File > Export, Save it to the hard drive.
In the forum page, below the message window, is the Attachment box, click on the Browse Link, Select the saved file.
Tunnel is the same process, using a Path and solid Pipe (as a Cut), through your material.
or making as 2 bodies, you can Combine > Cut one from the other.
Might help.....
Message 19 of 30
andrecasselbergs
Thanks for the video, I will watch it again and see how it will help me, I think this may lead me to the solution.
Message 20 of 30
andrecasselbergs
@wersy : I followed the video, created a 3D path using the angles I need and when I tried the Sweep, I got an error message that said "The start direction of a path segment is antiparallel to the end direction of the previous path segment".
So I ran a sweep with "chain selection" switched of and got a sweep that went 50% around the path and no further. So I ran a second sweep from the other end of the path and it joined up seemingly OK but still not as easy as your example.
Could this be because your example has everything running parallel and/or perpendicular (i.e. all angles are 90 degrees)?
