Sweep feature leaving thin walls
jmattson8WUR3
jmattson8WUR3
How would I get the sweep feature to get rid of all this material? It's leaving a thin wall on my part, even after extending my sketch beyond the stock.
Warmingup1953
I could not see why your Profile was not acting as desired but there must have been an oncontinuity I guess. I created a new sketch and made sure it was adequateQTView.jpg.
jhackney1972
If you Trim the indicate line, in your sketch, the Sweep works fine.
John Hackney, Retired
jmattson8WUR3
Thanks, trimming that line did work. I guess that makes sense to me, but why didn't it leave a thin wall in the middle of the profile where there's another line?
jhackney1972
Because that line really is hiding a fourth profile.  In the animated GIF below, at the beginning you see three profiles.  Then I use a Crossing Windows to select across the line and then you see four profiles.
jmattson8WUR3
Interesting. Thanks so much for the thorough explanation and pics.
