- Mute
- Permalink
- Report
Hi, I am a beginner trying to learn about Fusion Sweep Body function, I am having a problem to sweep the body along the path and trying to use the same path line as the twist aixs but keep getting errors. Tried using a constructed axis also same problem, tried creating another solid line also error. Only when I click the default axis then it works. Of course I can work around by drawing my sketch around the default axis as the center point. But then what is the usage of the field "Twist Axis" for if I cannot select another axis besides the default one.
Also, when I tried switching from the selection of "SIngle Path" , "Path + Guided Rail" and then back to "Solid Sweep", the "Twist Axis" is missing.
Appreciate if someone can help to explain if this is a bug or my poor knowledge
Thanks.
