SVG
2 REPLIES 2
thorxx
532 Views, 2 Replies
SVG
New in using the program.
Made some design in inkskape and imported this into fusion 360.
Looks fine, and I can extrude, move, scale.
However what if one want to change the design using fusion 360?
I can't seem to able to change anything of the svg-design..
2 REPLIES 2
jeff_strater
in reply to: thorxx
Hi thorxx, welcome to Fusion.
The reason you cannot change the imported SVG geometry is just that it is "fixed" in the sketch.  We do this on the assumption that you do not want to inadvertently change imported geometry.  If you do want to edit that geometry, just select it, and choose "Fix/Unfix" from the context menu.
Here is a short screencast showing how:
Hope this helps,
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
thorxx
in reply to: jeff_strater
that worked great 🙂
 is it only possible to scale and move svg-artwork once?
as I can scale and move it when I import. but afterwards it seems stuck to that placement and scalement.
