SVG Insert Tool Idea
bfjMCV4N
bfjMCV4N
Community Visitor
Community Visitor
Hi! I quickly searched the forum, but didn't find anything that seemed similar, but if I have missed it, I apologize.
Anyways, as a new user coming from Rhino, I find the process of importing/placing/scaling SVGs incredibly tedious. To make the process easier, my proposal is that whenever you import an SVG, the default behaviour should be that it is imported and placed within a cage (bounding box). This cage can then be scaled, dimensioned etc, but locked to the proportions of the graphics. Similarily, the graphics inside can't be modified unless the cage is broken.
This is typically how I have always worked with these sort of graphics, and it has worked great so far, but if you see any issues with this approach feel free to add your thoughts.
Cheers!
Bjorn
HughesTooling
For now you might find the preference Scale entire sketch at first dimension helpful. It does mean all sketches will scale when you add the first dimension but I find I sketch to the correct ratio most of the time so it helps most of the time.
Mark Hughes
Owner, Hughes Tooling
