SVG file imports but does not extrude
johnhoge
johnhoge
I'm having problems with an SVG file that I have imported into Fusion360. I can import the SVG into a sketch, but when I try to extrude it I get a problem. The first letter does not extrude for some reason.
The SVG file was directly saved from Illustrator. Not sure why this does not work.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @johnhoge,
I think the issue is in the curvature of the S. If you look at the screencast below, it seems as if something got a little bit wonky (I zoom in the video to show the error). A workaround I did was to project all of the good curves and recreate the two bad curves I found. Once done, it should work okay after that!
Let me know if you have any questions or if that works!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
johnhoge
Thanks James!
I would never have found that! I ended up fixing the ai file and re-exporting.
John
