Surface Workspace: How to patch a ring?
Sungod3000
Sungod3000
im getting into the surface workspace to learn to fix step files to make the watertight.
I want to connect the brow cap to the rest of the body.
however when I use the patch tool i close the whole area, i just want to connect the little ring around the cap thats missing.
what would be the right tool for that?
Cheers F.
2023-07-28 11_59_52-Autodesk Fusion 360 (Personal - Not for Commercial Use).jpg
TheCADWhisperer
@Sungod3000
Tip: Take a closer look at the options available in the dialog box in your image.
davebYYPCU
Not Patch because the boundaries are independent.
Connect the black highlighted line with the blue highlighted line with Loft.
Might help.....
Sungod3000
Hi, i fixed it with a ruled surface, that should also work in similar situations.
but im still curious if that works with patch
TheCADWhisperer
I don't understand why you posted this file - it doesn't seem to match your original problem description.
And where is your Timeline?
