Surface Structure
Surface Structure
Surface Structure
Hello community,
I was wondering if you guys could help me.
I would like to bring a pattern along a surface & then cut it out. (like on the picture)
Also: is there a way of populate Objekts onto a surface in general?
🙂 Thanks for your support.
SaeedHamza
Create an offset plane, then extrude cut From Object as a start ( from the dialog box ) and then use a circular pattern to make the first row
Now the annoying thing is that the pattern scale differs for every row, so you'll have to do the above every row, because the extrusion profile that will be extruded should be bigger from the one below it
Regards
Saeed Hamza
cekuhnen
@Anonymous
I am close to say that currently fusion does not have efficient tools to make this.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
