Surface Patch Problem
TimSirJohn
Message 1 of 11
TimSirJohn
Hey there
I searched for this particular case, but didn´t  find it, maybe because of my bad englisch and i  didn´t know what to search for.
I have small problem, maybe you have an idea??
Thank you, Tim
Replies (10)
Message 2 of 11
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach to post.
günther
Message 3 of 11
HughesTooling
You have a couple of options. Create the patch like in the video then use the inner sections of the tube to trim a hole. Or create plane on at the end of the tube, project the edges from the inner and outer tubes then create the patch from the sketch profile.
I think the visual problem is just because you have a small feature on a fairly large body so not getting a good mesh. You can set the meshing manually if you right click the body in the browser and select Display Detail Control and select Fixed High.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 11
TimSirJohn
Hey Günther, here is the file. Maybe a short screencast would be good, i have problems to translate/understand and follow the instructions of Marc... i don´t know how to trim with the inner hole as i don´t how how to select e hole to trim...
Thank you for your time guy`s!
Tim
Message 5 of 11
TimSirJohn
Hey Mark, the Detail Problem worked fine 🙂
The other one, i have some problems to do, i understand, what the way is you mentioned, but i don´t know the single steps/Clicks.. But still thanks a lot!
Message 6 of 11
g-andresen
recreate the part!
1. project the path into a sketch
2. create a sketch on a plane on the path
3. project the pipe profile into this sketch
4. sweep the pipe profile along the path
5. project the holes onto the new pipe
6. extrude the drill profiles
I show you how to do this in the screencast.
günther
Message 7 of 11
HughesTooling
Create the patch like in your video then use trim to cut the hole.
When prompted the select the cutting tool click the inner part of the tube.
Then clicking the centre part of the patch should create the hole. Note this will only work if the inner and outer tube sections are accurate and the ends are planer.
See attached file for the steps.
Mark Hughes
Message 8 of 11
TimSirJohn
Hey Mark, perfect, it worked out :), thanks a lot!
Thanks again!!!
Tim
Message 9 of 11
TimSirJohn
Hey Günther, thanks also for your way, this is maybe a "cleaner" way to do.
I wonder how you projcected the path into a sketch, can you show me?
Thanks a lot!!
Tim
Message 10 of 11
g-andresen
Instead of sweep, I have used the more simple Pipe tool here.
Follow the screencast:
1. activate design history
2. create sketch on xz and project the pipe contour into
3. create a pipe (square = 30mm)
4. apply fillets
5. shell > walls = 1,5mm
günther
Message 11 of 11
TimSirJohn
Hello Günther,
thank you, now i got it!!
Thanks for taking the time to record the video!
Grüße aus Hamburg,
Tim
