Surface from revolve, is it possible ?
Today I've drawn a profile with a single line (not an area)
I tried to revolve it in the model and patch space, wihout success.
Is it possible to create a surface from a revolve ? In autocad I could. I want to thicken the surface after to transform it into a body.
JDMather
You should be able to Revolve surface in Patch environment.
Are you selecting one of the Origin axis as your axis of revolution - or do you have a sketch line to revolve about?
Can you File>Export your *.f3d file and attach it here?
I don't want to revolve a surface, I want the end result to be a surface,
using the revolve function...
Dom
michallach81
here:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
PhilProcarioJr
@Anonymous
Hard to say exactly what the solution to your problem would be without seeing your model, but say you have a solid body cylinder and want to turn it into a surface. All you have to do is switch to the patch environment and delete the top and bottom caps and it will become a surface.
The preferred method to create such a surface would be the way @JDMather showed.
Phil Procario Jr.
Owner, Laser & CNC Creations
JDMather
That is precisely what I did.  I revolved a line to create a surface body cylinder.
Then I Thickened the surface body to create a solid body.
My solution exactly solves the problem description as you stated it.
If you would like to provide a new problem description - include additional information as required.
You are correct thank you !
Next question : How did you do these red arrows ?
Thanks and respect ! 🙂
