Surface area inspection
aleksei_ovsienko
aleksei_ovsienko
So my problem is this. I want to select a bunch of surfaces and know their combined area.
I can select them but then if I press "I" for investigate the selection clears.
I can press "I" for investigate first. But then when I start selecting surfaces the system won't let me select all of them. It starts deselecting them because it doesn't get what I want to do. It thinks I want to measure between things. This is incredibly fristrating.
Am I missing something? Is there an easy way of selecting all the surfaces I need to know the area of and measuring it?
rosie_lucas1
Hi @aleksei_ovsienko ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Rosie | Community Manager
MichaelT_123
Hi Mr Aleksei_Ovsienko, Mrs Rosie_Lucas1, Others...
The issue is also causing a frequent twitch in the upper-right corner of my right eye
Am I going to a doctor... seeking Pfizer medication? No!
I will wait until TF360 builds a simple logging facility into the measure dialogue.
A basic text log file in a simple format, such as CSV, fed in FILO or LIFO manner, would allow post-processing of measurement results using common software tools.
Such an addition should be trivial... so I can afford... 5 short years, can I?
Regards
MichaelT
P.S.
" fed in FILO or LIFO manner "
... without units ... and particulary inches! I have got the allergy!
MichaelT
kandennti
Hi @aleksei_ovsienko -san.
One of the problems in Japan's 3D CAD exam requires answering the total surface area of multiple specified faces after modeling. I created this add-in to help prepare for that question.
https://github.com/kantoku-code/MENSEKI
Unfortunately, the display is in Japanese.
aleksei_ovsienko
Dōmo arigatōgozaimasu.
I've taken the liberty to have it translated to English and uploaded to git for everyones benefit -
It has an executable .cmd file for quick installation as well.
https://github.com/ergilion-tech/Fusion-Gadgets/tree/main/MENSEKI
Collective programming is the way we beat Fusions problems -
