Support queston
Support queston
kit47JEY
Observer Observer
Support queston
kit47JEY
Observer
Observer
I have a lofted surface that I'm trying to start an extrusion from.  Having selected the sketch it will only let me select one part of the loft (see light grey selection) but the sketch covers mutple segments. Is there a way of either getting rid of these segments in the loft or using some other method to do this.  I solidworks It lets me select multiple segments to extrude.
Thanks for any help.
Chris
jeff_strater
This appears to be a duplicate post: problem-creating-and-extrusion-onto-a-loft-surface
Please see that other thread for a response and a request to share the model.  Keep all responses on that other thread.
Jeff Strater
Engineering Director
g-andresen
please share the f3d file for reply
günther
TrippyLighting
If it is a surface loft, make sure it is stitched to the surrounding surfaces.
Then you can select that entire stitched-together surface body in the viewport or the browser to extrude to.
TheCADWhisperer
@kit47JEY
If the design is proprietary, then simply make up a dummy file that exhibits the same behavior.
