Support for multiple target bodies and tool bodies in the “Combine” command
eliaskoller11
Observer Observer
Message 1 of 1
eliaskoller11
Observer
Observer
Currently, the “Combine” command in Fusion 360 only allows you to select a single target body and multiple tool bodies. However, in many projects it makes sense to combine multiple bodies in a single step
Therefore, I suggest extending the “Combine” dialog so that multiple target bodies and multiple tool bodies can be selected and processed in a single operation. This would speed up workflows and reduce the number of “Combine” operations required.
Examples/use cases:
Creating multiple cut-outs at the same time
If, for example, you have a design in which several bodies are to be cut out at the same time, you would currently have to select each target body separately and assign the same tool body several times. Multiple selection would simplify the work enormously here.
Combining complex assemblies
If several components in an assembly are to be merged into one body, it would be practical to merge all target bodies in one go.
Save time and clicks
Less switching between different dialogs and fewer individual operations make work more efficient and clearer.
Advantages:
Reduced time expenditure: Instead of carrying out several “Combine” operations individually, everything can be done in one step.
Better overview: Fewer entries in the timeline and fewer manual steps.
Fewer sources of error: Having only one operation reduces the risk of forgetting a body or combining it incorrectly.
Additional notes (optional):
Perhaps this could be implemented via a “Select multiple target bodies” checkbox, which only extends the known UI behavior without replacing it.
A similar logic as is possible with the tool body
Translated with DeepL.com (free version)
Replies (0)
