Super Simple Plasma Art Not Tooling
kmcgheeCMFPG
kmcgheeCMFPG
I have never had a super simple file like this give me an error, I cannot find the problem and I am pulling hair out. I watched my student create it yet it does not work. Please help!!
mavigogun
The error message would be useful- it's from the CAM set up:
Warning: One or more passes were discarded due to linking constraints.
Warning: No passes to link.
Generation completed with 2 warning(s) in 5.2s.
Warning: Empty toolpath.
kmcgheeCMFPG
Anyone know why it does not work? Still baffled.
norbertut
I have not managed, after some tweaking, to find the issue.
I have changed setup operation to "cut", added extra stock in case it needs to plunge before cutting, played with Link parameters and nothing. Sorry...
Lars Christensen explains it here, in case you see something that may help.
https://www.youtube.com/watch?v=2M0pwqe-r1M
TrippyLighting
This might also be a good post for the CAM forum.
Looking at the sketch of this object I can see that there are 2 semi-circles in this object with 0.01mm radius.
When I remove those and make these edges sharp, then everything works.
While CNC machines love radii/fillets a fillet this small is really not helpful.
