suggestion: object that was created by mirroring => mirror operation in timeline
maker9876
maker9876
When you click on an object that was created by an extrude, the extrude operation is highlighted in the timeline.
SUGGESTION: when you click on an object that was created by mirroring, the mirror operation in question should be highlighted in the timeline.
ps I really don't get the idea of the Feedback Hub (which somehow replaces the Ideastation): where should I copy /paste this suggestion there?
laughingcreek
Mirror icon in the timeline already behaves the way you describe for me.  can you screen cast an example of what you mean?
maker9876
`Here's an example where I click on a couple of items and we see what happens in the timeline.
Labour of love making screencasts.
https://autode.sk/2vFwhGw
laughingcreek
interesting.  Your original question referred to extrusions, so that's what I checked.  It works as expected with mirrored bodies,  but doesn't work with mirrored  components.  I also noticed it works with copied/pasted components, but doesn't work when you "create component from bodies".  This does seems to be inconstant behavior from a UI point of view.  @jeff_strater -thoughts?
maker9876
It's not just that it's inconsistent, it's also potentially quite hard to find "where" in the timeline an entity was created, necessitating a trial and error approach.
