subassembly issue
subassembly issue
estersanz.32X
subassembly issue
estersanz.32X
I want to move the flat-head, hex-key and triangular-key into the BITS assembly (image below), but it doesn't work. I've attached the file.
First, I created all the bits (flat-head, hex-key and triangular-key). Then I created the BITS component and finally I tried to move all the bits into it, but none of them worked as expected.
Does anyone know what's happenning?
Thanks in advance.
Ester
jeff_strater
For reasons I can no longer remember, the timeline marker must be at the end of the timeline to restructure your design.  In doing that, I noticed that you "Remove"d the flat-head bit.  I'm going to assume that was not intentional.  So, I deleted the two Remove features, and then I could drag the bits under the BITS component.  See the video:
Jeff Strater
Engineering Director
estersanz.32X
Hello @jeff_strater,
Thank for the video, I tried what you did and it works for me as well. I didn't know that the timeline marker must be at the end. And yes, I deleted the flat-head by accident.
Thank you very much for your help!
Ester
