Renderning a section cut
scotty71
Message 1 of 36
scotty71
How do I do it?
Scott
Replies (35)
Message 2 of 36
innovatenate
Autodesk Support
Autodesk Support
Hi Scott,
Great Question! It looks like the Section Analysis tool is not supported in the Render environment at this time. I also checked the cloud rendering and creating a saved view with the section analysis visible and saved.
You may be able to work around this limitation by creating an extrude cut to that passes through everything (all bodies/components). You can override face appearances as necessary and then use the Render environment.
I hope this helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
Message 3 of 36
Hi- is there any movement on getting this functionality?  I'd love to be able to render various sectional views.  Thanks!
Message 4 of 36
colin.smith
Hi @Anonymous
We have this feature in our backlog.  I don't have a release date yet, but I'm hoping the team will be able to get to this before the end of the year.
There are some large projects ahead of it that need to get completed.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
Message 5 of 36
Jasoncake
Have you guys done it yet?
I'd like this feature too
Message 6 of 36
colin.smith
 Hi @Jasoncake
No this hasn't been implemented yet.  I will update this forum thread when I have a date that it will be added to Fusion.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 7 of 36
RandScullard
When this does get implemented (hopefully soon!) it would be ideal if it worked the way it does in Thea Render: Lighting, shadows, reflections, etc. behave as if the hidden portions of the model were still visible. So, the result is not the same as if you removed or hid portions of the model. See here for more: https://thearender.com/forum/viewtopic.php?f=17&t=17531
Message 8 of 36
_ritchie
Yes please! And if it worked w/r/t scene lighting as Rand describes in the Thea Renderer post, that would be fantastic!
Message 9 of 36
riander73
For my purposes I would like the behaviour to be the opposite. I.e. the render should look like the part has been physically cut in half and I am looking at the remaining material in the part.
Hence a switch to toggle between the two behaviours would be optimal.
Message 10 of 36
rodrigo.alvarez
It's been a year. Is this implemented?
Message 11 of 36
dhaeg
Any updates?
Sincerely,
Another user who'd like to render a cross section, thanks!
Message 12 of 36
+1 !!!!!! Lets get some traction please... Or a workaround.
Message 13 of 36
sam
Hello, Its been couple of years and Fusion doesn't have this functionality, Right??
Message 14 of 36
danielfrenkel
Yes, please!
Message 15 of 36
xmaspako
FIVE years have passed since this post.
I'm another user that would like to use this feature.
May we trust it will be implemented?
Thanks in advance
Message 16 of 36
colinNJB25
My marketing department has requested a bunch of renders of the tanks I have been drawing including animations and cutaways to show internal functionality. @colin.smith is this still on the roadmap or do I pass the project on to another team mate using different software?
Message 17 of 36
rodrigo.alvarez
Unfortunately, as wonderful as Fusion is, being on the roadmap has come to mean that there may pass >5 years before things are implemented.
I don’t have any insights into the Fusion team, but from what I’ve seen, you should probably find a workaround.
Message 18 of 36
elliot
+1 !
Message 19 of 36
colinNJB25
I ended up getting a project assigned to me that required this. The object had about 30 components. I split all of the components with a plane and hid half of them. I then rendered the object as normal and my marketing team was happy with the results.
Message 20 of 36
I found this to be a solution which worked well.
1. Created cube that intersected with my design, such that the intersection was where I wanted to view the section.
2. Used 'Modify->Split Body'
3. Selected tool as the cube I just created
4. Selected as targets all those bodies I wanted cut at the intersection.
5. did a bit of clean up.
A slightly more streamlined feature would be nice, but I don't see any real need.
