- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I feel like I'm making progress learning F360 - I've made some drawings I'm happy with. I've taken a zillion tutorials. But I still get hung up on some simple basics. I started a new design and wanted to do everything I could in sketch first - just for discipline sake. I WANT to make this:
But I tried to do it 1st in sketch:
1) I wanted to repeat that circle across the construction line. Move/Copy won't give me a copy option. Pattern won't let me select the circle. Aarrggh! Why not? (I used Pattern on the "holes" in the body with no problem - I just wanted to do it from sketch mode.
2) I created that counterbored vertical hole on the right (top image) (using the hole tool on the body, not sketch) - and I want to DUPLICATE it at the other end of the part. I can't seem to copy it- again the "move/copy" tool doesn't present "copy" as an option, I can select the profile and CMD+C but pasting....doesn't.
I feel really stupid. I really did try to search the forum first, I promise! The tutorials are always good at showing you how to do something but they aren't so good at explaining why some stuff that seems like it should be obvious from available functions just doesn't work - like I'm missing some key concept.
