student newbie... i cant extrude items from a second sketch plane
brent9A4N7
Message 1 of 8
brent9A4N7
I am a student working on a problem for a test.
I created a second sketch plane to keep things organized- projected the key parts needed from the base geometry.  now i cannot extrude the items from the second sketch plane-   the pallet.  ive tried everything - even copying the pallet sketch into the base geometry sketch- still will not allow me to extrude the pallet.  im missing something.     the thin extrude feature works but thats not what im trying to do ...
I would like to know what im doing wrong so to avoid that on the test  🙂
https://a360.co/44vkAQV
Replies (7)
Message 2 of 8
Drewpan
First thing, there is no additional user created plane in this file. There are only two sketches.
Sketch one is way too complicated. Sketches should only do one or two things. After you
have extruded the sketch, use the tools to sculpt your model. For example use one sketch
to create the basic wheel and extrude it. Use another sketch to create ONE of the gear teeth
and extrude it. Create a Circular Pattern using the Gear Tooth as the feature to pattern.
Your first sketch is also not fully constrained. A very bad habit to have. In simple models it
usually is not an issue but in more complex models, a number of unconstrained sketches
can break your model so badly it is easier to start again from scratch.
The reason that you cannot extrude the second sketch is because it is not blue in the centre.
This means that the lines of the sketch do not form a closed shape.
The sketch IS fully constrained .
But you have created it from a whole bunch of line segments that might overlap but are
NOT joined together.
Remember, you can only extrude a shape that is closed. You know it is geometrically
closed if the inside of the shape is blue.
Cheers
Andrew
Message 3 of 8
brent9A4N7
Thank you for the advice.  ill review it for sure.
unfortunately im taking horology engineering drawing class- unknown to me when i selected fuzion, that for testing purposes they want to see all the construction lines on paper.   I only have 3 hours to complete a drawing like this.  they want a front view showing all the construction lines for the wheel and pallet  on a drawing along side  a  sectional view.     the only way i found to do this quickly is to convert all the construction lines  in a sketch to normal  after extrusion.  when its drawn the line thicknesses are consistent to the standard.  im expecting to be time crunched and thought if i had multiple sketch planes it would be harder to convert all that geometry for the final drawing.
ill certainly give it  shot.  thank you again,
Brent
Message 4 of 8
Drewpan
What a Kool subject to be offered. If you are interested in Horology then "Watchmaking"
and "The Practical Watch Escapement" both by George Daniels are cheap and excellent
references. George was an absolute Legend. He DID Write the Book.
Don't Panic! Fusion has a way to create engineering drawings directly from the Model.
Model it first. Get it right. Use the AI to create the basic Assembly and Component
drawings. Modify them if necessary after.
Quickly look at the documentation on how to do it but it is straight forward. The Model
is the hard bit that everything else is based off. Afterwards go back and read the docs,
do the embedded tutorials and the Self Paced Learning. This time spent is NEVER wasted.
Cheers
Andrew
Message 5 of 8
g-andresen
1. as @Drewpan said, the profile is not closed
2. the divide and conquer method helps
3. the cause is a short line, which is designed as a construction line and thus prevents the profile from being closed.
(view in My Videos)
günther
Message 6 of 8
brent9A4N7
now i feel stupid...  thank you for the video 🙂
Message 7 of 8
Drewpan
Don't feel stupid, learn from your mistakes. We are here to help people just like you.
We also started just where you are. The only difference between you and me is the
amount of experience you have.
Cheers
Andrew
Message 8 of 8
brent9A4N7
wanted to thank you for your help.
