- Mute
- Permalink
- Report
Not happy with the update today it killed screen casting.
After getting that working, I am stuck with patterns - again.
See screencast:
I have made a block with 6 screw holes on the top.
There are 6 wire connection points below.
You can see the screw holes.
I make a rectangle (though there is an existing one but....) on the face of the "block" and then try to pattern it.
It won't. Weird, because this is what I remember I did to do the screw holes on the top side.
