Stuck in portrait mode
tom_trotobas
tom_trotobas
Hello, me again.
I needed to do some renders in portrait mode, but now the window of rendering is stuck in portrait mode, making it really really painful to make other renders (as it takes roughly the center of the portrait mode screen to scale renders. Awful.
CGBenner
@tom_trotobas
Can you share some more information about what you are trying to do and what is not working?  Maybe some screen shots would help the experts here understand what the problem is.
Chris Benner
tom_trotobas
Yes sure, here is my render view:
Here are the settings:
And despite changing the setting in yellow below, it stays stuck in this view.
So let's say i want to render a 16:9 ratio image still, this is - roughly - the part of the screen that will be used:
So a 16:9 ratio image, in a 4:5 ratio window, which makes renders painful as I need to approximate the window it will take into account, the result below (it's bad quality, but you get the idea)
laughingcreek
if you want your on screen scene settings to look the same as your renders, you have to set them the same. -
Warmingup1953
You appear to be set up for Cloud Rendering (and no credit is available). Why not set it for Local render?
tom_trotobas
Thank you so much that's it! I 'm pretty sure i didn't mess with this setting, strange but i'll keep an ey on it in the future!
Cheers
tom_trotobas
No it's for both modes, i've tried 😞
