Struggling to Loft 2 components
lonewolfgrips
Observer Observer
Message 1 of 11
lonewolfgrips
Observer
Observer
Hi All . very new to Fusion and I'm struggling to join 2 different sized circles using a Loft. I used it before on the same 2 components but when it came to printing , the loft part did not match the wall thickness of the 2 circles and it tried to print a very thin wall rather than a 4 mm thick wall .
Any advise will be appreciated
https://a360.co/4acDWey
Replies (10)
Message 2 of 11
dsouzasujay
Hi @lonewolfgrips .
Requesting to either provide access to download the file or directly attach the .f3d/.f3z file in the next reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 11
TheCADWhisperer
@lonewolfgrips
Create the hole through the center after lofting between cylinders?
Can you use Revolve instead of Loft?
Message 4 of 11
CCarreiras
Hi!
Try using revolve instead of loft.
Better sketch control, simple feature and more predictable result, comparing with loft.
Use loft on more organic or variable geometries between profiles.
CCarreiras
Message 5 of 11
johnsonshiue
Hi! There are multiple ways to create the shape. You may create Loft surface between the two circular profiles. Then use Thicken command to solidify the surface with a constant thickness value.
Many thanks!
Software Test Engineer
Message 6 of 11
lonewolfgrips
Observer
Observer
Thanks . The problem was that i could create the loft in the first place . but I eventually got it and used the 'thicken' function .
Message 7 of 11
lonewolfgrips
Observer
Observer
 . Hopefully this is the correct File Type that you can view and modify ? So I managed to Loft the top and bottom together and printed it . The problem now is that the top wasn’t attached properly as it's too thin where it joins the Loft section . I'm still trying but any help is greatly appreciated.
Message 8 of 11
lonewolfgrips
Observer
Observer
Hi There . Thanks for the Help . File attached . I managed to create the Loft but when printed , the top flange detached because it was too thin where it meets the loft .
Message 9 of 11
g-andresen
1.  No!
2.  share f3d file
     File > export > save as f3d on local drive > attach to post
günther
Message 10 of 11
TheCADWhisperer
@lonewolfgrips
You cannot use email Reply to attach files - you must use the web forum.
I already Attached the solution file in previous response Message 3, but you should attach your file here so that someone can explain why it didn't work as expected.
Message 11 of 11
lauri_barnhart
Hello, @lonewolfgrips,
Just checking in—did the responses shared by @TheCADWhisperer, @CCarreiras, @johnsonshiue or @g-andresen help clarify your question? Also, did you happen to see the requests for the f3d file from both @TheCADWhisperer and @g-andresen?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
