- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Sometimes I need to 3d print small protrusions on a flat surface. The problem is that the protrusion only rides on the top layers, it does not "anchor" into the material. This method I use is to ensure the protrusion goes into the print for a deeper foundation type anchor.
In a nutshell I create a small offset between the faces which my printer will never be able to print, so it just welds it together. I add Cura examples of before and after. The effect now is that the protrusion does not break off so easily - especially small protrusions that is typically used in mounting holes for PCB's. This is akin to planting a pole in a deep hole and not just sitting at grass roots level.
Anyone with abetter method, please please help me out!
Regards
