Strange Stitch artefact
ninolemann
ninolemann
I'm Trying to make a solid out of a surface from a cast plastic part.
I failed, so i started to dissect the surface around the red edges highlighted by the STITCH-tool.
I found this really small piece, which claims to be the main body, but its clearly no longer attached. it has two free edges, so i cant close up my body and make a solid.
(see picture)
can someone maybe help me out???
Kind regards
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
ninolemann
Thanks for your reply,
I uploaded it again, this time it works fine as a solid..
Problem solved for me.
