STP FILE IMPORT ISSUE
When I imported a step file to fusion 360, one part has a weird extra surface which should not appear. As I showed below:
Anyone could give me some idea or help me fix this issue?
Thanks a lot!!
dsouzasujay
Hi @Anonymous,
I'm not sure which is the extra surface from the image. It will be helpful if you can share the STP file with us.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
