Difficulty using Image2Surface
mikesmsproductions
mikesmsproductions
I recently added the Image2Surface script to Fusion and for the past hour now, I've been trying to use it to create a model of a portion of the lunar surface. Each time, it's excruciatingly slow to start (takes well over 5-10 minutes just to get the dialog box where I choose the image), slow to process (I assume it's processing) and then slow to attempt to create the model. I say attempt because it has never actually created a model. After a few minutes, a dialog box pops-up asking me to overwrite the image file. I click "OK" and then it says "Failed to execute command: Can not create Mesh bodies in parametric mode." I don't know what it means but I've tried it in the Surface, Model, Patch, and Mesh environments. Each time it came up with the same dialog. I just changed my modeling settings from "Do not capture design history" back to "Capture Design History (Parametric)" with the hopes that maybe this will work. Can anyone help me with what's going on here?
innovatenate
Autodesk Support
Autodesk Support
The Read Me for that  script states that you need to create a BaseFeature in Parametric/timeline model.  Have you tried that?
Nathan Chandler
Principal Specialist
mikesmsproductions
I just tried that and it worked. Thank you.
