STL friendly???
STL friendly???
STL friendly???
What are the odds of making fusion 360 more sol friendly. I recently downloaded the Mesh add-in and is better, but being able to use basic operations like booleans (cutting), or even brush sculpting will be awesome. I give courses and having to use mesh mixer and going back and forth is not very good for beginners. I think it could be easy and a very good addition to such a robust software.
Thanks in advanced,
masa.minohara
Hi @Anonymous,
Thank you for posting! Have you tried Mesh workspace? I assume you are able to do what you want there.
Please note that you need to switch to Direct modeling mode by clicking "Do not capture Design History" in the browser to access the Mesh environment. I hope this information helps!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Hi Masanobu,
Yes, I've tried but is not possible to do any boolean operations for intersecting meshes. I think this could be really easy to implement and I really need it since I mostly work with STL files and they loose quality if converted to quad bodies.
masa.minohara
Oops... sorry I was only thinking about combining bodies. I think you may consider submitting your idea to the Fusion IdeaStation forum, which is constantly monitored by developers and product managers, and is currently the most effective way to request a product enhancement:
Other forum users will have the opportunity to Vote or add Kudos to the Idea. Votes on an idea will increase the likelihood that an idea will be implemented.
Masanobu Minohara
