Im using F369 makers version and my question is: If I export a model to STL file do I lose the original file?
Solved by Drewpan. Go to Solution.
When you export a file you are creating a copy in a different format. The original model will still be available to change
or modify and export again with the changes.
Cheers
Andrew
