Hello everyone.
I'm quite new to the 3d design world as so far i've only used thinkercad.
My issue is the following:
I've made an hairclipper holder in fusion 360, and i've imported an stl file in the design (the pegboard holder).
I've placed both objects correctly, but when i try to export the design for 3d print, only the parts designed in fusion360 are exported.
I've attached the file for reference.
How can i fix this?
I've also noticed that the 2 components are not bonded together in the stl file, as when i look at the file layer per layer i can see that the first cube is inside the second one and they are both hollow inside as it can be seen in this picture:
I guess i'm making some rookie mistakes, can anyone point me to the right direction? thank you
