STL file import: Opens in web browser "my hub"
sohnrog
sohnrog
I imported an STL file and it shows up in my data panel.  When I double click to open it, I get a web browser page where I can look at the object but it doesn't open in 'fusion.  What am I missing here?
Roger
HughesTooling
In the Fusion data panel right click the i on the part icon and choose Create Fusion Design.
Mark
Mark Hughes
Owner, Hughes Tooling
innovatenate
Autodesk Support
Autodesk Support
You can also use the Insert Mesh command from the Insert Menu as well.
If you are in a parametric design, you may need to use Create Base Feature or Create Form first, before the Insert Mesh command will be added to the Insert menu.
I hope that helps.
Nathan Chandler
Principal Specialist
HughesTooling
Another option is to use Upload from Fusions Data Panel and the file will be converted to a Fusion design automatically as it uploads.
Mark
Mark Hughes
sohnrog
Thanks for the suggestions. I'll try it.
