STL export ignores actual rotation of object
AlphaRay123
AlphaRay123
I've first time designed an object rotated (backlight holder for my bike).  The initial sketch is "standard" on x/y. I rotated first after extrusion.
For printing i rotated the whole object back -40° and exported as stl - The stl file is still at 40°.
Screenshots attached - showing the object wile rotation. And the exported, rotated object in cura.
Added screenshot of the stl module from front. Here you see that the preview of stl is "flat" - as the object actual is - and not rotated.  The only rotated here is the origin. It seems that the stl export uses the origin rotation and not the actual object orientation.
jeff_strater
I think you rotated the component that this object exists in.  Component transform is ignored on STL export.  If, instead, you rotate the Body, the STL will reflect that rotation.
Jeff Strater
Engineering Director
AlphaRay123
You're right - i rotated the component.  Good to know. Thank you!  🙂
