.stl appears larger
.stl appears larger
aljaz.segula95
Message 1 of 10
.stl appears larger
aljaz.segula95
hy guys.
I have some .stl files which appears bigger when import in F360.
When 3D-printing the same files, the object is ok, but imported in fusio360 is bigger.
I also have some .pts file for tool path, and when I import it, its just okay on the object, but is also bigger??
Any clue?
here is the file
Replies (9)
Message 2 of 10
TheCADWhisperer
You don't mention intended size.
You don't mention intended units (inch or mm)?
Message 3 of 10
laughingcreek
when you use "file-open" to open a .stl fusion uses a cloud converter.  this converter assumes cm as the unit. regardless of what your model units are.
if you use insert, the model will come in using the units your model is currently set for (should probably be mm) gives you a dialogue box allowing you to set the correct units-
FWIW, this has been a long standing source of confusion.  so far AD hasn't bothered to address the problem because, quote "there's a work around for it".
Message 4 of 10
aljaz.segula95
Thanks that solved one of my problems.
Now I have to scale down 10x Cvs.
What is the best way to do it? Beascuse it obviously get in cm to fusion.
Message 5 of 10
TheCADWhisperer
@aljaz.segula95 wrote:
What is the best way to do it? Because it obviously get in cm to fusion.
If you set the correct Import Mesh Units - you should not need to scale anything.
Message 6 of 10
aljaz.segula95
I correct it, but splineline which i import as CVS is still 10x bigger
Message 7 of 10
TheCADWhisperer
This sounds like a new issue.
It should be in a new thread (this thread was about stl mesh files).
And include the actual file.
Message 8 of 10
aljaz.segula95
No, I have written it when opening thread, that I have problem with Cvs too
Message 9 of 10
TheCADWhisperer
Can you Attach that file here?
You should be able to Scale after import of the file.
Or maybe only on inserting.
Message 10 of 10
laughingcreek
...Now I have to scale down 10x Cvs.
that's what this setting is for-
place your first dim between 2 points of known distance, and enter the value the distance is suppose to be.  the whole sketch will scale accordingly.
