Hi guys
I am in desperate need of some assistance
i am trying to produce a nose for a SR71 blackbird.
I have the profile, The sketched object is the 1st former of the airplane, the outer edges cannot be modified, or it will not fit the airplane.
I have inserted the 2 view canvases,
I have tried this on my own, but cannot make any real progress,
What am i to do next?
i have been trying to find some sort of tutorial video on how i can get this shape just right, but either i am searching for completely the wrong thing, or i am just stupid. 🙂
Solved by davebYYPCU. Go to Solution.
Limited information, limits how much to say,
You need to decide if you are doing half with mirror, or quarter with 2 mirrors, or the full complicated version. Twice or four times the same work makes for more errors to creep in.
(I would do a quadrant and mirror twice.)
Loft will work, with another former at the nose, and "enough rails" to make the accurate shape.
Loft needs 2 profiles, and rails to pull the shape into place.
Share the file, we may be able to give more details.
Might help.
that really helps thank you so much 🙂
I was trying to do too much at the same time.
Breaking it down into top/bottom, then left/right is the easier option for me,
that wall I need do is mirror the individual pieces once, as the profile is different from top/bottom 🙂
I was just looking at it completely wrong. 🙂
thank you.
Hi @Anonymous,
Thank you for asking about this in the Forum
Yes, I would agree with @davebYYPCU, just sketch half of the nose and mirror it.
I have just seen that your sketch´s are still blue, so not constraint.
Could you make sure that they are all constraint, so you see the Red Pin on the sketch icon and the lines appear black 😉
Thank you,
