Square Root Function
ksheehan
ksheehan
I am having an issue with the Square Root function. I am trying to create a Parametric Geneva Drive by following Rob Duarte's tutorial -- https://www.youtube.com/watch?v=tju7pLETqDg
I am trying to set up the parameters and am unable to enter the formula for b1 which should be -- sqrt(c1^2 - a1^2)
Any Suggestions?
Tutorial parameters
My parameter file:
ksheehan
I discovered the unit of measure was causing an issue. I was able to resolve the problem.
Hi what do I enter to get the square root symbol or the command for square root in my parameters please?
systemerorr41
type sqrt(number you want the square root of)
example:
square root of 5
sqrt(5)
