Please help with first project
I just installed fusion 360 and am working on   my first project.
I'm having a problem with extruding.
I'm drawing a sign base that has a pocket in the bottom of it, and it will also have a door.
I have drawn the base and the pocket.
I also need 6 door support features (4 in the corners and 2 on center line)
When I draw the door supports, and then extrude them to the bottom of the pocket, they also "lock" onto the
base surface and then I cannot reduce he height of them (.25) for the door to sit on.
I'm attaching picture to help explain what I'm trying to achieve.bottOM OF SIGN BASE marked up.pngJPEG_20170401_094747_1832404392.jpgJPEG_20170401_094947_288844154.jpg
TrippyLighting
If you can share your model this this is easier to explain. Export as .f3d and attach to next post.
it wont save to a file on my computer.
what am I doing wrong?
I have no idea what its doing.
TrippyLighting
File->Export choose .f3d format. Pick location on your hard drive.
thank you for your help
TrippyLighting
Peter,
Thank you very much for your help.
I am very new to CAD and have MUCH to learn.
Thank you again.
