I'm trying to print a design containing a couple of PC fans. Its actually going to be a flat sheet type design similar to the attached (I'm just playing for now), but unfortunately its too big for my 3d printer.
So I need to print it in two halves.
I'm lucky that I'll be bolting PC fans to it, so if I stagger the split as per the blue line I can use the bolts for the fans to hold it together. I appreciate I'll also need some length ways support once I've split the two halves.
I messed around a bit with split face/split body but couldn't quite seem to make it work. Is anyone aware of a tutorial covering this scenario of something resembling a flat sheet? Or if not, can you point me (an inexperienced user) at the methods I ought to be using.
Thanks in advance
