Message 1 of 12
I'm trying to draw the attached box in sheet metal. I need this as a flat pattern to cut out on CNC. The box has one side with a longer angle than the other three sides that doesn't mate properly when using flange command. Also, I cannot get the upper corners to miter same as the other three corners. I can use the unfold command and draw the miter corners but I get and error when re-folding. Can you help?
Thank you,
