Splitting a large body
979jules979
Message 1 of 14
979jules979
Hi there, I am trying to split a long facia panel into two parts so that I can 3D print each half. However, every method I have tried comes up with 'compute fail', probably because the mid plane does not extend fully throughout the model, but leaves a bit not included.
Here are two grabs of the two methods that have failed. I think using some sketch method might work, but I'm not clear where and what to draw to do it.
Any suggestions on how to cut the model to split?
Jules
Replies (13)
Message 2 of 14
dsouzasujay
Hi @979jules979 ,
Can you please attach previous designs that you've completed in Fusion?
Please export your design as a *.f3d/*.f3z file to your local drive and then attach it to your reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 14
TrippyLighting
@979jules979 wrote:
... probably because the mid plane does not extend fully throughout the model, but leaves a bit not included.
That is definitely NOT the case. Planes are infinite!
Message 4 of 14
979jules979
Here you are.
Jules
Message 5 of 14
kacper.suchomski
(view in My Videos)
Kacper Suchomski
Message 6 of 14
g-andresen
works as expected
(view in My Videos)
günther
Message 7 of 14
979jules979
Well, not for me. Another 'split error' as in grab
Jules
Message 8 of 14
979jules979
I can split the front face, but I need to also split the middle boxes that are left in place. These boxes are just position by the appertures. Perhaps I need to used solid 'jopintys' and then it will all split instead of just the front face?
Jules
Message 9 of 14
979jules979
I have split the relevant parts separately and then joined them together again. Messy, but it works. Thanks for the demos.
Jules
Message 10 of 14
kacper.suchomski
Divide or separate (move)?
Because these are two different goals.
Kacper Suchomski
Message 11 of 14
TheCADWhisperer
@979jules979
You write "split face" but you should be writing Split Bodies.
Why do you have multiple bodies?
Why are none of your sketches fully defined?
Would you be willing to start over from scratch and simplify the design process with step-by-step instructions?
Is this really the Design Intent (missing Tangent Constraints)?
Message 12 of 14
g-andresen
Your first question:
Even the inserts consist of 2 solids each.
Why?
(view in My Videos)
günther
Message 13 of 14
TheCADWhisperer
@979jules979
The deeper I dig into this model the more things I find that probably weren't intended.
We can significantly improve your design process.
(view in My Videos)
Message 14 of 14
TheCADWhisperer
@979jules979
Attached is a simplified model.
Note the shorter Timeline.
Note the red lock glyphs indicating every sketch is fully defined.
