Splitting a body with a 3 dimensional splitting tool
ewchampney
Observer Observer
ewchampney
Observer
Observer
I am trying to split a body using a tool that is not flat. Is there any way that this can be done?
splitting tool: Autodesk Fusion 360 1_14_2018 5_35_24 PM.png
laughingcreek
Modify-Splitbody
Hold down the ctrl key to select multiple faces for the splitting tool, or select the body to be used as the splitting tool from the browser
etfrench
Model workspace:
You can use sketch geometry to split.
The Combine tool can also be used to split a model by using it several times to create both sides.
Patch workspace:
Create a patch object, then use it as the split tool.
Here's an example using a spline (with revolve) in the Patch workspace:
ETFrench
