Split fails while it clearly intersects
cekuhnen
Mentor Mentor
cekuhnen
this works when the patch tool (highlighted in time line) is set to G0 and not G1 !!!
in addition the stitch tool complains about the patch tool not lining up well !!!
check the red internal edges - even with G0 this happens !!!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Phil.E
I'd like to help with this, but the model you posted does not match the images. Do you have a copy of this that contains the geometry shown in the images you posted? That will help me reproduce any problems you are finding.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
cekuhnen
@Phil.E Wow nice Fusion exported no the state I was in ! Here is the correct version. adjust the patch continuity setting and the split will fail
Claas Kuhnen
Phil.E
Did you export from Fusion? That should provide the current state of the model. If you export from A360, I'm pretty sure you just get the last saved version.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
cekuhnen
@Phil.E If something bugs I export instantly to capture that moment from Fusion.
I dont use the A360 a lot to be honest.
Claas Kuhnen
Phil.E
Got it, bug logged.
Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
cekuhnen
@Phil.E Great filling up the bug tracker this week I see.
That patch tool really is amazing.
I don't want to see the internal CV and isopram layout but it does do things where in Alias I ah well lets not talk about it ...
Claas Kuhnen
