Split Face question
Split Face question
Split Face question
Hello, I was recommened to post this question here instead of CAM forum, so sorry for the double post, I am new and dont know my why around this place yet 🙂
Anyway..
How come I cant select several shapes from my sketch to be part of the "Splitting Tool" in "Split Face" dialogue ? I can select other things like parts of the body but not more shapes from the sketch. Am I doing this wrong or is it just a limitation?
catot
Seems to be a limitation, I can also only select a single profile for the split.
HughesTooling
It looks like you can only select one tool so a workaround is extrude all the rectangles then add a box across all the extrusions to form one body, something like this.
Then select the body as the splitting tool.
Mark
This method is probably only useful if you have a lot of profiles to cut, something like text where you can window select all the curves and extrude.
Mark Hughes
Owner, Hughes Tooling
Mark, thats actually how I have been working around it sofar, but perhaps this should go in the ideas section then because that work around is a bit...workaroundish 🙂
