Split Component
Split Component
maple15207
Split Component
maple15207
I'm trying to crop a component. Basically cut out 100mm from each side. Not sure how to split a component. there's split body and split faces. Neither applies here when I try to select Body. How do I do it?
Thanks.
jhackney1972
A component can be split, the same as a body, because a component has been created using a body.
(view in My Videos)
John Hackney, Retired
maple15207
I am not able to select a body using what you have said. How do I select it?
Thanks.
davebYYPCU
Your body is a Mesh body, not many normal tools will work.
Go to Mesh section.
Create a Plane at Angle on your sketch line.
Use Modify > Plane Cut on the body with the plane you just created, with trim setting..
Might help....
