Split body vs splt components paterns
Message 1 of 9
Hello
I have a problem with SPLIT BODY .
When I split pattern of bodies I get a different effect than I split pattern of componnents.
What am I doing wrong ?
Here are two examples:
https://a360.co/2FQr5TK
https://a360.co/2Ulc0N7
BR
Marek
Replies (8)
Message 2 of 9
jeff_strater
this is a fundamental "bodies vs components" misunderstanding.  When you have multiple instances of the same component, they all share the same geometry.  If you make a hole in one of them, that hole appears in every instance of that component.  Bodies, however, are independent entities, and, even if they look identical, they are not.  Put a hole in one Body, it will not affect other bodies.  So, when you split several bodies, each split can be unique.  Split a component, and they all are affected.  Here are a couple of youtube videos that explain bodies vs. components:
Jeff Strater
Engineering Director
Message 3 of 9
thank you.
How can i break this links between multiplicated components ?
is it possible ?
Message 4 of 9
and...
Is it possible to:
- the parent modified the child but the child does not modify the parent ?
BR
Marek
Message 5 of 9
in this case, I made SPLIT components without inheriting features.
Why ?
I apologize for ignorance
https://a360.co/2G3EbfJ
Message 6 of 9
TrippyLighting
@Anonymous wrote:
and...
Is it possible to:
BR
Marek
A pattered (or copy/pasted) component creates identical instances that all reference the exact same data set. There is no child/parent relationship.
Message 7 of 9
Thank You.
How can I edit individual components after they have been copied inside the project, without affecting the others?
BR.
Message 8 of 9
etfrench
Copy|Paste New.  Removing or hiding the original is better than deleting it.
ETFrench
Message 9 of 9
O.K.
Thank You.
And next
How can I edit a single component if I want to use component PATTERN?
When I Patern to body inside component the link is break. When I make components from this "paterned" bodies, and modify thise componets the links breaks to.
Is this the correct way?
Sorry for my English.
BR
Mrek
