Spline method
Spline method
Spline method
In Fusion360, can I select spline method (control vortex or fit)?
The default setting seems to be control vortex. I opened a DXF exported file in AutoCad and checked it.
colin.smith
Hi @Anonymous,
Can you explain in a little more detail what it is you are trying to do?
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
On AutoCad, there are two type spline method "Control Vertices" and "Fit" (cf. figure).
I exported a sketch drawn on Fusion360 in DXF file and opened it on AutoDesk, spline method was set "Control Vertices".
Can I change this method to "Fit" on Fusion360 without using any other CAD software?
colin.smith
Hi @Anonymous
There is currently not way to change the Spline type in Fusion.
Colin
Colin Smith
Sr. Product Manager
SketchBook
